Big Humm with expression pedals
Home Forums Products Stompboxes Big Humm with expression pedals
Viewing 3 reply threads
    • #114262
      Dalmanours
      Hi everybody,
      First I apologise for my bad english, I’m french…
      So here is my problem:
      I’ve got a mission engineering (the special H9 gear) who’s directy connected to my H9.
      And I’ve 2 another expression pedals connected to my Voodoo Lab GCP. There IS not two pedals assigned to the same gear of course. But I have a really big humm who stops when I disconnect either the mission who cames with H9 or the one who is connected with GCP.
      I don’t know what to do. So Could you help me?
      Thanx by advance.
    • #146780
      Je suis desolé, but it sounds as if you have a ground loop in your connections – this is beyond our ability to diagnose.
      Try using different cables, and re-arrange the wiring. Make sure things are only grounded at one place (no more, no less).
      If you cannot fix it, you will probably need to get a local technician to have a look.
    • #146782
      Dalmanours
      Thanx for your answer, I just hope I will find a way to solve. I will be back with News.
    • #146806
      Dalmanours
      dalmanours wrote:
      Found it ! I have screwed my pedals on my PB who’s metallic… unscrewed them and it’s ok.
      Thanx for help guys !
