Black Hole immersive problem with Studio One Dolby Atmos setup
Home Forums Products Plug-Ins Black Hole immersive problem with Studio One Dolby Atmos setup
    • #183612
      audiobong
        Hi There. Im having an issue with BH Immersive when I try to use it in a Dolby Atmos project in Presonus Studio One. Im on a Mac Studio max M1 running Sonoma 14.4.1 and Studio One 6.6.1.
        When I create a Surround FX channel with BHI as an insert I get nothing when I try to send a signal to that FX channel. If I bypass BHI I get an input signal again on the FX channel. This only happens in Dolby Atmos projects. If I create a normal surround project and do the same, it works fine. There seems to be something going awry when the Dolby Atmos renderer is involved. Im on the latest version of BHI. Ive tried reinstalling but that didn’t make any difference. Any ideas? Cheers
      • #183649
        ndeshpande
          What Atmos channel format are you trying to load?
          I suggest you contact support@eventide.com with support info from Blackhole Immersive – right click the Eventide logo in the upper-right hand corner of the plugin window and select “Copy Support Information to Clipboard” and then paste that info in your e-mail to support. We can help you diagnose and debug from there.
        • #183663
          audiobong
            I found the solution. The FX channel was set to a different surround format than the atmos renderer. My setup is 5.1.2 and once i selected that on the FX channel, it began working again. Thanks for the reply.
