Blackhole bug : in and out level
Home Forums Products Plug-Ins Blackhole bug : in and out level
    • #115881
      Hey there!
      I’m a new Blackhole user (been using it for 2 months now),
      and i keep having the same bug : whenever i copy/paste a section of a track using blackhole or when i move it elsewhere in the project, the in and out level of the blackhole goes to 0 (with weird automation points), so my track is mute.
      It is easy to fix it as i have to remove the automation points but i have to do it everytime which is kind of a pain in the ass..
      i’m using ableton9 on mac.
      Does is happen to anyone else? Do you have any tips?
      Thanks for your time and help!!
      Cheers
      Max
    • #154662
      tlongabaugh
        Hi, if you are using AU, this is a known issue with Blackhole AU and Ableton 9. The issue was fixed in Ableton 10. You can use the VST version of Blackhole, which should work properly.
      • #154762
        OK thanks,
        So i’ll try to put it as VST then,
        Cheers,
        Max
