Blackhole do not work with ProTools 10
Home Forums Products Plug-Ins Blackhole do not work with ProTools 10
Viewing 3 reply threads
    • #111702
      romakomar
        Hej everybody.
        Just got Eventide BlackHole plugin. Followed the installation guide and step by step installed to my computer. Everything seemed to be fine, but ProTools keep giving me a message about my aax plugin can't be open cause it is damaged or no license on iLok.
        After rechecking and reinstalling the problem appears again. It is not license or iLok problem because BlackHole running on Garage Band just fine.
        Does anyone had the same problem? If yes, how did you solved it? Any other suggestions?
        Im running ProTools10 on MacBook Pro with Mac OS X 10.7.5
        Thanks a lot
        Roman
      • #126137
        DGillespie
          Hi Roman,
          Which version of Pro Tools are you using?  Due to a change in Avid's SDKs the latest build of Blackhole is compatible with Pro Tools 10.3.6 or higher only, which is a free upgrade of Pro Tools 10 users.
          Dan
        • #126143
          romakomar
            Hej Dan
            Thanks a lot for fast reply. It definitely helped!
            I had ProTools 10.0.0. After upgrading up to 10.3.9 Blackhole running just fine.
            Thanks again.
            Roman
          • #136838
            DGillespie
              Great Roman,
              I'm glad,
              Dan
