Blackhole Immersive – Reaper Routing
Home Forums Products Plug-Ins Blackhole Immersive – Reaper Routing
Viewing 3 reply threads
    • #187909
      Smuff
        I have a 5.1.2 system and when I set up Blackhole Immersive on an 8ch track in Reaper, it displays the routing for 7.1. Is there a way to tell the plugin which spatial format to use?
        Many thanks
        S
      • #187910
        Smuff
          Also the output is L C R rather than the dolby atmos L R C?
        • #187929
          pmcculloch
            Hi Smuff, unfortunately Reaper just specifies the channel count, not the layout, so we don’t have a way of knowing whether we’re getting 5.1.2 vs 7.1 (or 7.1.2 vs 5.1.4).  Reaper also only provides even-numbered groupings, so formats like 5.0 and 7.0 are not available.  Hopefully this will change soon as it’s my preferred DAW, too.
            Though the meters and gain sliders are laid out visually L/C/R, the plugin’s output will be L/R/C.  You can confirm this via the following:
            1. Set the plugin to 8 in/8 out
            2. Set Crossfeed to 0%.
            3. Add an instance of JS Pink Noise in front of Blackhole Immersive, and set it to have 8 outputs.
            4. Route the “left output” column of the Plugin Pin Connector for the pink noise to “track channel 2”.  You should see the metering for “R” illuminate.
            5. Disconnect the connection from the previous step, then route the “left output” column of the Plugin Pin Connector for the pink noise to “track channel 3”.  You should see the metering for “C” illuminate.
            Please let us know if that is not the case.
          • #187939
            BEAST Technician
              Hi thanks for getting back to me. Could i request a manual way to specify the routing in leu of an automatic system and also it would be great if the visuals matched the order. That said It is a great plug in and none of this is a deal breaker. Thanks again. Best S
