Blackhole, In/Out and Live
Home Forums Products Plug-Ins Blackhole, In/Out and Live
    • #113372
      sierenmusic
      Hey,
      I’m running into a little issue w/ Blackhole.
      Namely when I duplicate a clip in Live’s arrangement, an automation gets introduced
      setting Blackhole’s Input and Output sliders to -60db.
      Can someone verify this behaviour or am I overlooking something?
    • #143019
      tlongabaugh
      Hi-
      Thanks for bringing this to our attention, I've been able to reproduce it here in AU and will look into a fix. Is it indeed the AU version of Blackhole that you're seeing a problem with? If so, you should be able to use the VST version without issue, that version appears to be fine.
      -Tom
      • #143031
        sierenmusic
        Thanks Tom, indeed it was the AU version. I’ll stick to the VST version for the time being then. Thanks 🙂
        Matt
