Blackhole Logic Presets
Home Forums Products Plug-Ins Blackhole Logic Presets
Viewing 4 reply threads
    • #115273
      Blackhole in Logic shows no presets, what to do?
      thanx, Beo
    • #151686
      tlongabaugh
      Hi, sorry to hear it. What version of macOS and Logic are you running?
      Also, can you confirm that there are .tide presets saved under /Users/<your username>/Documents/Eventide/Blackhole/Presets?
    • #151687
      Logic Pro X 10.3.3, Mac OS 10.11.6, presets are saved in documents.
    • #151689
      tlongabaugh
      Thanks. Sounds like that checks out.
      Can you confirm that you are using the plugin dropdown in the Blackhole plugin, and not the Logic preset browser? Also, if you hit "Load" in the Blackhole preset bar, does it open a dialog showing your documents folder?
    • #151694
      It works with “Load” !
      Thanx and best regards,
      Beo
