- This topic has 11 replies, 3 voices, and was last updated 2 years, 9 months ago by
Eventide Staff.
December 2, 2023 at 8:07 am #176435
Hello!
I’ve downloaded both Blackhole and Micropitch but they will not show up in logic. i’ve tried uninstalling, moving components around, reinstalling, restarting computer, etc. but no matter what i do, Eventide doesn’t even show up as a manufacturer in my list of plugins! I run plugin manager, and it says both have been successfully validated, but as you can see, the Audio Units dropdown doesn’t show Eventide ! I am on OS Ventura 13.4, on a Apple M1 Max Macbook Pro.
December 4, 2023 at 12:06 pm #176502
Can you please make sure you have the latest version of iLok License Manager installed? Once you have done that, please try the following:
- Uninstall your plug-ins using the uninstaller
- Open up Logic to scan for plug-ins, then quit the app
- Deactivate the licenses using the License Manager app.
- Restart your computer
- Install the plug-ins
- Open Logic. You should be prompted to activate the licenses.
Let me know if that helps.
December 6, 2023 at 4:20 am #176546
Hey, no it still doesn’t show up 🙁
December 6, 2023 at 9:20 am #176547
Can you please let me know what version of Logic you are running?
December 8, 2023 at 8:46 am #176609
10.7.9
December 8, 2023 at 8:56 am #176612
Sorry you are still having issues. What happens when you click one of the Immersive plug-ins and select “Reset & Rescan select”? Are there any error messages or does it validate correctly?
Please try the following steps:
- Close Logic Pro X
- Make sure Finder is the active application
- While holding the Option key, click on the Go menu at the top of your screen and select Library
- Delete the following files from your User Library, if they are present:
~/Library/Caches/com.apple.audiounits.cache
~/Library/Caches/AudioUnitCache/
~/Library/Preferences/com.apple.audio.InfoHelper.plist
~/Library/Preferences/com.apple.audio.SandboxHelper.plist - Then, open a Terminal window (located at Applications/Utilities/Terminal), and enter the following commands (type each command and press “Enter” afterwards):
- killall -9 cfprefsd
- killall -9 AudioComponentRegistrar
- Restart Logic Pro X
December 11, 2023 at 1:47 pm #176665
When I Reset and Rescan select they validate correctly.
I tried the following steps twice, still doesn’t show up! 🙁
December 11, 2023 at 3:19 pm #176668
Just to confirm, have you setup your project in Logic to be surround? You can check this by creating a new project in Logic, and setting the output to “surround”.
The Immersive plug-ins will not show up in a stereo Logic project since the plug-ins do not support stereo layouts.
December 20, 2023 at 6:18 am #176852
My project is not in surround, still doesn’t show up
December 20, 2023 at 9:49 am #176861
Sorry if my last response was not clear, but if your Logic project is not in surround, then the Immersive Plug-ins will not show up. So, this sounds like the correct behavior.
You need to use a surround project in Logic to use the Immersive Plug-ins, they are not compatible with stereo formats.
If you’d like to test if the plug-ins are showing up correctly, you’ll need to test this by creating a surround project in Logic.
December 9, 2023 at 7:11 am #176627
The same problem.. i did everything still wont show up
December 11, 2023 at 10:31 am #176654
Sorry to hear you are having issues. What version of Logic are you using?
Can you please provide some more information about what you have tried? There are many troubleshooting steps I have suggested in this thread.
Are the plug-ins showing up in Logic’s plug-in manager? What happens when you click one of the Immersive plug-ins and select “Reset & Rescan select”? Are there any error messages or does it validate correctly?
