Blackhole midi preset change?
Home Forums Products Plug-Ins Blackhole midi preset change?
Viewing 5 reply threads
    • #172127
      nickrobinson
        How can I change Blackhole presets in ableton using a midi controller? I use a midi dummy clip to send program change messages on another VST, but you suggest we use the preset interface within the plugin itself.
      • #172128
        nickrobinson
          I can use chains to switch presets, but that uses more instances & processing power.
        • #172170
            It’s not possible to load the plug-ins native presets using PC messages.
            If your DAW can support loading presets via PC messages for 3rd party plug-ins,  then that would be the best way to do it.
            Otherwise, you could send automation data to change the parameters you need instead of loading different presets.
          • #172175
            nickrobinson
              Can you pass the idea on to your developers? Having to change using a mouse is so clumsy. Ableton allows for what you suggest, but the preset list isn’t populated.
              Send automation data? That’s what presets are for!
              black
            • #172176
                Sure I can make that suggestion, but I can’t promise that this feature will be added.
                In the meantime, you can populate the preset list in Live and that should allow you to achieve that setup.
              • #172185
                nickrobinson
                  I have created a folder and saved presets into it, which I can access through the plugin window. However, these do not show as a drop-down in the ableton window ;(
