May 30, 2012 at 3:58 pm #108808
xtrust
MemberHI, I bought blackhole native plugin … just amazing …
….. but why is only 32-bit and not 64-bit?
Roberto
May 30, 2012 at 4:26 pm #123497
A 64 bit version is under development but not yet available. Why are there only 24 hours in a day ?
June 27, 2012 at 9:57 am #123590
ellance
MemberHi, is there a plan to have the vst Plug-ins working on Mac ? Any idea about a time frame ?
Cheers from Paris.
June 27, 2012 at 4:58 pm #134646
There is a plan. It will come to fruition later this year. Can't say more than that at this time.
July 4, 2012 at 6:16 pm #123615
kaboom
ParticipantIf you are on Windows installing Jbridge will run 32bit plugs in a 64bit DAW
I just tested Blackhole with Ableton Live 64bit beta on Win 7 64bit and it does work if you have Jbridge installed.
Think their is a mac version of Jbridge called JbridgeM. Try the Jbridge Demo.
December 4, 2012 at 2:09 am #124055
chrispire
ParticipantI'll be really happy when the 64 Bit AU is released. It's almost 2013 and nothing in my plugin collection has been 32 bit for a long time, so I made the mistake of assuming that Black Hole would be 64 bit. It's my bad, but I would not have purchased this plugin if the product description had been more informative and specified that it is 32 bit only.
March 29, 2013 at 8:55 pm #135328
dlwhite66
Participantwell it's 2013… 2nd quarter about to begin and no 64bit blackhole still. that's disappointing. If you hadn't set expectation for a 2012 drop, I wouldn't have bought it so early as I am now fully 64bit and I'm not buying a 3rd party bit bridge for the only plug-in I own that's still just 32bit. (UAD, PSP, Audio Damage, Ableton, Cakewalk – all 64bit). time to catch up!
April 13, 2013 at 10:34 pm #135350
Hi Guys,
I wanted to give an update to the state of 64 bit support. We have Blackhole and 2016 running on 64 bit, but we are having problems applying the licensing. We are working with PACE to quickly resolve this issue, but I can't say when exactly it will be resolved. I can promise that it will remain resolved and that is has been and continues to be a priority.
Thanks,
Dan
May 2, 2013 at 8:53 pm #135362
Hi Everyone,
Blackhole AU/VST 64 bit is now available. Please find it here:
More plug-ins to follow in the coming weeks.
Thank You,
Dan
May 2, 2013 at 9:57 pm #135363
kaboom
ParticipantThank all the team involved for me it's a great thing this 64bit I hate that ugly jbridge wrapper that's about to vanish.
May 3, 2013 at 1:08 pm #135364
Arion444
ParticipantReally having a problem with this download. How do I upgrade to 64-bit on my DAW computer? The file doesn't do anything…just opens a Windows dialog that asks which program do I want to open this file with?
Help?!
P.S. I have a registered 32-bit version on my DAW (Windows 7 64bit – Cubase 7 64bit).
May 3, 2013 at 3:44 pm #135365
Thanks Kaboom,
Sorry it took so long. Glad it's working for you.
Dan
May 4, 2013 at 11:32 am #135366
kaboom
ParticipantDon't know about Win 7 but for some amps windows 8 will not run things but in the pop up you can click run. Sounds to me like you tried to run the mac version of Blackhole installer.
Try this one Windows 64bit VST- http://www.eventide.com/~/media/Files/Audio%20Support/Plug%2 0Ins/Eventide%20Users/209189BlackholeVST1_1windows%20×64%20i nstaller.ashx
May 5, 2013 at 7:21 pm #124473
badmelonfarmer
ParticipantJust tried the updated Blackhole 64bit Audio Unit v 1.1 and it still does not work in Audacity.. I reported this issue last year and it was reproduced by Eventide support.
Not sure if this is an Eventide issue or an Audacity issue, although I dont have any problems with any other plugins in audacity?
Cheers
Martin
May 5, 2013 at 8:07 pm #124474
kaboom
ParticipantI would use something more like Ableton live than Audiacity as not many use it for music production.
May 5, 2013 at 10:59 pm #135367
badmelonfarmer
ParticipantI use Logic mainly as my DAW, I just use Audacity to quickly spice up digital recordings of rehearsals and one take demos…. A full DAW does not seem to work well for me for this workflow, an editor like Audacity / sound forge works better for me in this instance.
May 5, 2013 at 11:11 pm #135368
Hi badmelonfarmer,
We've been able to identify the Audacity issue and it's related to some funky ways that Audacity handles threads. Unfortunately the fix will involve a pretty big rewrite of a fairly central piece of code and I didn't want to hold up 64 bit support any longer for this. We're going to roll out 64 bit support to Omnipressor and SP2016, then we should be able to address this in an update down the road.
Sorry it can't be sooner,
Dan
May 6, 2013 at 8:06 am #135370
badmelonfarmer
ParticipantOk Dan, thanks for the info.
Martin
May 14, 2013 at 8:57 pm #135375
jimbourekas
ParticipantHello there. Should there still be a problem with 64bit licensing? I can't get my Cubase 5 x64 to see the license on the iLok. Any ideas? thanks
May 15, 2013 at 7:58 am #135376
jimbourekas
ParticipantOk, solved.
I uninstalled both client and driver, unplugged the ilok, installed driver without the ilok plugged in and then restarted when prompted. Works ok now for win7 x64 and cubase 5 d64.
jim
May 15, 2013 at 10:44 pm #135380
I'm glad to see that it's fixed, Jim. I've found that sometime after downloading a license I have to unplug and plug in the iLok before the license is recognized. I don't know why this is.
Dan
May 22, 2013 at 7:36 pm #135384
cyphersuit
MemberHey I've downloaded the windows 64 bit installer and installed the license on my ilok 2. but how can i open the installer? it asks me in which software i would like to edit the file…
May 22, 2013 at 7:40 pm #135385
cyphersuit
Memberi am a first time customer and i have the same 🙁
May 22, 2013 at 8:55 pm #135387
kaboom
ParticipantIf you are on Windows XP you need to install 7Zip to unzip the zipped download.
Once installed just go back to your downloaded file right click it and click 7zip then extract to here. Then double click the unzipped file.
December 16, 2013 at 6:06 pm #125094
badmelonfarmer
ParticipantActually, just an update …. i have realised you can you the "Scroll Wheel" function of the mouse whilst hovering over the virtual knob to control the values in Audacity.
YAY!
January 5, 2014 at 7:18 pm #136002
Antoine
ParticipantI'm blind? or where can I find the Blackhole installer for MAC VST?
January 7, 2014 at 12:47 am #136010
Hi Antoine,
Unfortunately, there is not yet Mac VST support for H3000 Factory or Blackhole. I hope to roll this into an update in the coming months.
Dan
January 7, 2014 at 1:07 pm #136012
Antoine
ParticipantOh….ok.
Thanks for your answer.
Would be nice for the next update.
January 7, 2014 at 4:03 pm #136013
badmelonfarmer
ParticipantJust out of interest what DAW on Mac uses only VST?
I must admit I tend to only use Audio Units on Mac, the very few DAWs i have used on the Mac have all used AU's and only a few have offered VST support.
Not sure if I have ever seen any that ONLY use VST. …so thought I would ask.
January 7, 2014 at 4:18 pm #136014
davidkaeser
ParticipantHi Badmelonfarmer 🙂
Cubase 7.5 uses VST.
January 7, 2014 at 4:26 pm #136015
Antoine
ParticipantCubase and Nuendo
Ableton Live do use AU and VST.
and maybe Studio one, but don't know.
January 7, 2014 at 4:39 pm #136016
badmelonfarmer
ParticipantAntoine:
Cubase and Nuendo
ahh, only used Cubase years ago on PC and never tried Nuendo.
looks like Studio One supports AU's …. just not in the free version
January 11, 2014 at 11:29 pm #136047
timdogao
MemberAny news on when a 64bit aax version of blackhole and h3000 will be available? I'm now on PT11 and they're my only 2 plugins that aren't available yet, any news would be greatly appreciated!
January 12, 2014 at 12:09 pm #136049
kptainfilou
ParticipantYes please, you're beginning to be awfully late with those two
January 12, 2014 at 8:46 pm #136050
svaughanmerrick
Participantagreed!
January 16, 2014 at 12:31 am #136061
Hi Guys,
I was planning on rolling these in with a handful of other changes and having them out in a couple months. However, I'm now trying to get just AAX64 and possibly Mac VST out sooner, then another release later.
We'll see what happens.
Dan
