Blackhole not showing in Ableton (PC)
Home Forums Products Plug-Ins Blackhole not showing in Ableton (PC)
Viewing 3 reply threads
    • #113840
      Peter Horsham
        I got the iLok stuff sorted, I think, and it says its “Active”. It just won’t show in Ableton (32bit). I’m running Windows 10.
        I’ve tried reinstalling to see if its a 32 / 64 bit thing. Ended up with them in two folders:
        D:VstPluginsEventide
        D:VstPluginsEventide64
        I’ve rescanned etc. and Its still not showing. I bought it through the Eventide website and it appears in my products place (where i can see my serial number). I have never entered or seen a license key though. Where is this and do I need it for installation ?
        Please help!
        Thanks
      • #144958
        tlongabaugh
          Hi-
          If you have activated the Blackhole license to either an iLok dongle or your local machine, you should be ok.
          You need to be *absolutely* sure that you placed the 32-bit dll in the 32-bit folder, and 64-bit dll in the 64 bit folder. If you aren't sure, run the installer again and point the installer to the appropriate location for each dll.
          In Live, make sure you have the 32-bit VST path set under Preferences->File/Folder->VST Plug-in Custom Folder (I assume you already do). Sometimes in Live rescanning is not enough, try turning "Use VST Plug-in Custom Folder" off and then back on again.
          Let me know if that does not work.
          -Tom
        • #145009
          Peter Horsham
            Thanks! All sorted now.
            When I clicked the custom folder icon in Ableton it crashed the whole operating system.
            On reboot Ableton scanned the VSTs again and it all worked.
            Great customer support – I also received a reply to my email so thanks again.
          • #151698
            Thanks.  I needed to turn off ‘Custom VST Folder’ off and then back on again and it recognized Blackhole.
