April 5, 2016 at 9:19 pm #113392
mrwolf
MemberI downloaded the Blackhole plug-in and have it activated through iLok. The plug-in shows up in Logic, but not in Ableton Live 9 Suite. I’ve tried to rescan the plug-ins folder, restarted Live but to no affect. How do I get the Blackhole plugin to show up in Ableton?
April 6, 2016 at 5:37 pm #143121
Hi-
I would try toggling "Use Audio Units" and "Use VST Plug-in System Folders" in the Preferences off and then on again. For whatever reason, sometimes simply hitting "Rescan" doesn't do the trick.
Let me know if that does not solve the problem.
-Tom
July 13, 2016 at 6:19 pm #143817
tclproductions
MemberI have a problem with Blackhole in Live – When you move a region with blackhole insterted it adds a Device on and off automation to that track rendering the track inaudible until you erase that automation
Hi-
Does this happen in the Audio Units of Blackhole? If so, this is a known bug that we've filed with Ableton, and the VST version of Blackhole should work fine.
If not, please let me know.
Best,
Tom
September 11, 2016 at 5:11 pm #144349
tclproductions
MemberTLongabaugh wrote:tclproductions wrote:I have a problem with Blackhole in Live – When you move a region with blackhole insterted it adds a Device on and off automation to that track rendering the track inaudible until you erase that automation
Hi-
Does this happen in the Audio Units of Blackhole? If so, this is a known bug that we’ve filed with Ableton, and the VST version of Blackhole should work fine.
Best,
Tom
Thanks Tom! – Yes AU
April 23, 2018 at 8:40 pm #149018
Didier Degey
ParticipantI would try toggling “Use Audio Units” and “Use VST Plug-in System Folders” in the Preferences off and then on again. For whatever reason, sometimes simply hitting “Rescan” doesn’t do the trick.
Just to tell that this solution (for the vst part) needs to be applied with a new install for Ableton Live 10 Suite 64 bits (Windows 10 Pro)
Simple rescan does not work, neither restart of Live.
Best
Didier
