Blackhole plugin missing in Logic
Home Forums Products Plug-Ins Blackhole plugin missing in Logic
Viewing 5 reply threads
    • #175641
      djretouch
        I have done some updates today, installing Logic 1.8 and Ventura. I thought I’d update all my plugins at the same time and have an issue where Blackhole is now only showing as “Blackhole (no midi)” in Logic. The standard blackhole plugin seems to have vanished and the projects which use Blackhole are showing the plugin as invalid.
        I have been into the plugin manager, located Blackhole, which it appears to find, and validated it without issue but this isn’t changing the invalidated version on each track.
        I hope someone can help because some of these projects have a fair bit of automation on the reverb and I feel a bit of rage building.
        Thanks,
        Charlie
      • #175642
        djretouch
          Note: I updated SP2016 at exactly the same time and this has loaded correctly.
        • #175643
          djretouch
            Apologies, I had not realised this was more widespread. I have just found the other thread with the workaround (which works for me). You can delete this thread.
            thanks,
            Charlie
          • #175968
            nurjhan
              Hi Charlie
              Could you perhaps share the workaround?
              Thanks in advance
            • #175969
              djretouch
                The workaround comes from an Eventide staff member, about 10 posts down in the thread below:
                Blackhole renamed in Logic 10.8?
              • #175970
                nurjhan
                  Thank you very much !
