Blackhole prevents Logic X Pro 10.3.3 to startup (after saving project with BH)
Home Forums Products Plug-Ins Blackhole prevents Logic X Pro 10.3.3 to startup (after saving project with BH)
Viewing 3 reply threads
    • #115420
      platt1963
        New owner of Blackhole and Ultratap here.
        I installed it and plugin showed up fine. Now I used Blackhole on a track and it played ok so I saved my project.
        But when I started Logic again Logic will not start up and gives no reason except a detailled report I don’t understand.
        Only after removing Blackhole from my Plugin folder Logic starts up ok. I placed the plugin back to the folder but the same happens again.
        I use Logic X Pro 10.3.3 and I have MACOS El Capitain 10.11.6.
        Hope for your help,
        Philip
      • #152292
        Hi Philip,
        Can you confirm you are using the latest version of the iLok license manager? Also, could you please give us the report you are getting?
        -Quin
      • #152301
        platt1963
          Hi Quin,
          I’m running iLOK 5.0.3 GM (b2559, r44013)
          So what happened this evening:
          I put Blackhole back in my plugins folder and started Logic.
          Then I inserted BH in a track and saved my project and restarted Logic.
          Logic went OK! So problem solved I thought. I repeated it a few times with success.
          After a while I rebooted my MacPro and I got the same problem, Logic gave an error.
          After my dinner I rebooted again and everything went ok.
          So next time it crashes I will send the Error log ok?
          Gr. Phil
        • #152324
          platt1963
            Well, so far I had no problems since I made this topic.
            Case closed I think and I’m happy.
