- This topic has 41 replies, 21 voices, and was last updated 5 months, 3 weeks ago by
Zodiac.
November 6, 2023 at 2:43 pm #175464
I just updated to Logic 10.8 and for whatever reason my sessions that have Blackhole now won’t load Blackhole anymore. I get a plugin not available error. This said, when I go into the Eventide menu, the Blackhole audio effect now lists as Blackhole (No Midi) and I can select it and it instantiates correctly. I am pretty sure this used to be just Blackhole for the audio effect and Blackhole (Midi) for the MIDI controlled effect.
Not sure if this issue is due to Logic 10.8 or a recent Eventide update, but my sessions won’t load Blackhole anymore.
Thanks,
Ken
November 6, 2023 at 5:57 pm #175470
I have the same issue. All my old sessions won’t load blackhole anymore. Really confused why this changed from just updating Logic. I had no issues until updating Logic.
November 6, 2023 at 11:46 pm #175476
I’m also having the same issue. I was on Logic 10.7.9 and Blackhole was working fine. I updated to Logic 10.8 and now it can’t find it. I even tried reinstalling Blackhole after and it still didn’t fix it.
November 7, 2023 at 9:28 am #175485
Same deal. I checked the Plugin Manager and both Blackhole and Blackhole (No MIDI) are properly validated. It looks like regular Blackhole only shows up now as a MIDI Controlled Effect in an instrument slot.
Maybe that was always supposed to be how it worked, but I’m pretty sure most of us saw “Blackhole” and just selected “Blackhole” whenever we needed that particular reverb.
Certainly gonna screw up a whole buncha my sessions if I have to convert everything over to the “No MIDI” version and lose all my custom settings.
November 7, 2023 at 9:44 am #175487
+1
November 7, 2023 at 9:55 am #175489
Same problem here. I dropped back to Logic 10.7.9 just so I could avoid this. (I hope you feel flattered, Eventide.)
November 7, 2023 at 1:50 pm #175498
While downloading new stock library sounds, I did notice an interesting message. “Blackhole – Do not have access rights”
November 7, 2023 at 1:56 pm #175499
Same issue here!
Hope this can be fixed soon as I’m unable to finish my project now 🙁
November 7, 2023 at 2:22 pm #175500
We are aware of the issue and investigating. “Blackhole” should show up in the normal inserts menu, not just as a MIDI Controlled Effect in an instrument slot. We will report back as we have new findings.
November 7, 2023 at 2:24 pm #175501
Great to hear that you’re on it!
November 7, 2023 at 3:29 pm #175502
I’m also having this issue with Guitar Rig 6, just fyi, so it appears to be affecting other manufacturers as well.
November 7, 2023 at 5:07 pm #175505
<p style=”text-align: left;”>I’m also having this issue with Guitar Rig 6, just fyi, so it appears to be affecting other manufacturers as well.</p>
November 7, 2023 at 5:08 pm #175506
Same here. AU Lab loads it so it seems to be a Logic issue as it also claims to validate it – just doesn’t show it.
November 7, 2023 at 9:12 pm #175509
It does seem that Logic 10.8 changed some internal behavior which broke plug-ins from multiple manufacturers. It seemingly affects plugins with both a standard and MIDI-enabled version.
As a workaround, the following steps seem to enable “Blackhole” to show up in insert slots, but of course only work if you are not using “Blackhole (No MIDI)” in your sessions:
- Close Logic Pro
- Navigate to Mac HD/Library/Audio/Plug-Ins/Components/, and move Blackhole No MIDI.component to your Desktop.
- [Edit 11/8/2023] Restart your computer
- Open Logic Pro
- “Blackhole” should be available in the insert menus
We will continue to update this thread as we have more information.
November 8, 2023 at 1:13 pm #175538
That workaround also worked for me too. Make sure you restart your computer. I didn’t at first and didn’t work. Once restarted Blackhole loads fine on older projects.
November 10, 2023 at 8:34 am #175578
Thank you! You just saved me from having to re-do a ton of automation work before sending a track off for mastering.
November 8, 2023 at 4:02 am #175512
Mhh for me this workaround is not working. I moved (not copied) the Blackhole no MIDI.component to the desktop, but (after restarting Logic) the same error appears..
Is it working for others?
November 8, 2023 at 8:51 am #175517
This worked for me, just bare in mind you need to log out and back to work properly. Mangledverb and Quadravox work fine, no need of anything.
It does seem that Logic 10.8 changed some internal behavior which broke plug-ins from multiple manufacturers. It seemingly affects plugins with both a standard and MIDI-enabled version. As a workaround, the following steps seem to enable “Blackhole” to show up in insert slots, but of course only work if you are not using “Blackhole (No MIDI)” in your sessions:
- Close Logic Pro
- Open Logic Pro
- “Blackhole” should be available in the insert menus.
November 8, 2023 at 9:00 am #175518
It doesn’t work for me either.
I also tried moving the same .component file contained inMac HD/Users/[username]/Library/Audio/Plug-Ins/Components
but the problem still remains.
November 8, 2023 at 9:10 am #175519
Worked for me. Make sure to press command while dragging the No Modi version out of the Components folder. If you don’t press command while dragging, it may simply copy the plugin to the desktop, but not move it out. Try that and see if it works for those who said it doesn’t work. Worth a try.
Thanks,
Ken
November 8, 2023 at 9:14 am #175520
I followed the advice: after moving both files I restarted the computer and now the plugin works.
November 8, 2023 at 1:40 pm #175544
Yes, you need to be sure Blackhole No MIDI.component is moved from Mac HD/Library/Audio/Plug-Ins/Components/ to the Desktop, rather than copied.
Restarting your computer might also be required, to get Logic to refresh its plugin caches.
November 12, 2023 at 3:57 am #175644
Okay, this worked for me. I’m wondering if this is the final solution until the next Logic update (with a file.component on my desktop :-). Thank you so much.
P.S. Both Blackhole plugins worked on my Logic 10.7.9. The issue came up when I updated to Logic 10.8.
November 10, 2023 at 10:09 am #175583
It worked for me as well, after a restart.
November 10, 2023 at 10:31 pm #175622
I am also experiencing this problem. An additional detail that I don’t think anyone has mentioned previously:
In the Plug-In Manager, both “Blackhole” and “Blackhole (No MIDI)” appear. Both show as successfully validated, and both have the box checked in the “Use” column.
I strongly suspect that this will turn out to be a bug in Logic Pro 10.8 when the name of 1 plugin is identical to the name of another up to the length of the shorter of the 2 names.
November 12, 2023 at 4:57 pm #175653
Okay, this worked for me. I’m wondering if this is the final solution until the next Logic update (with a file.component on my desktop :-). Thank you so much. P.S. Both Blackhole plugins worked on my Logic 10.7.9. The issue came up when I updated to Logic 10.8.
This appears to be a bug in Logic 10.8. Both plugins have worked side-by-side (without issue) since Logic 9. We have submitted a bug report to Apple, and are in touch with our contacts there. Hopefully they can resolve the issue quickly.
You could move the Blackhole No MIDI.component file to the Trash, if you don’t want it cluttering your desktop. Once the issue is fixed, you could uninstall / resintall the plugin, and it will reinstall the necessary components.
We’ll keep this thread updated as we have more information.
November 13, 2023 at 2:18 am #175661
This appears to be a bug in Logic 10.8. Both plugins have worked side-by-side (without issue) since Logic 9. We have submitted a bug report to Apple, and are in touch with our contacts there. Hopefully they can resolve the issue quickly. You could move the Blackhole No MIDI.component file to the Trash, if you don’t want it cluttering your desktop. Once the issue is fixed, you could uninstall / resintall the plugin, and it will reinstall the necessary components. We’ll keep this thread updated as we have more information.
Thanks so much!
November 13, 2023 at 4:19 am #175662
Just jumping on this thread with a message for the devs – in case there’s an update to Blackhole required as part of this issue could you also fix the Freeze (doesn’t freeze) issue reported elsewhere – that would be awesome thanks 🙂
November 14, 2023 at 3:26 pm #175725
Was just about to bring this up and glad to see this was resolved as I have project due. I only had to restart logic, not my computer, but prob best to restart computer anyway. Thank you all! Life savers…B
November 27, 2023 at 12:42 pm #176181
Thanks for this!
November 27, 2023 at 10:02 pm #176207
I’m glad I found this thread after two days of banging my head against the wall with this issue. Thanks.
But I experienced something strange that may be a problem for others, if it wasn’t a bug on my system. Following steps in another thread to recover missing plugins, I re-installed the H9 Bundle 1.0.10 osx-installer. Checking HD/Library?Audio/Plug-Ins/… all H9 plugins were present (Component and VST3, in my case) except for Blackhole standard and No MIDI versions. I downloaded the installer twice and reinstalled three times so could there be an issue with this version of the installer, itself?
November 28, 2023 at 2:22 pm #176246
Hi, we’re not able to reproduce the H9 Bundle issue you mention here. Does uninstalling (the installer can be found at Mac HD/Applications/Eventide/Uninstallers) and reinstalling cause the Blackhole plugins to show up on your drive? If not, please email support@eventide.com and we can assist you further
November 28, 2023 at 8:42 pm #176286
Thank you for the follow up.
Something probably went haywire when I installed multiple times, on my system, and deleted preferences in Library, etc. as instructed on other pages. I didn’t know about the Uninstallers! I’ll have to keep them in mind for the next time.
I worked around it by installing the Blackhole solo app. So far so good.
November 30, 2023 at 2:02 pm #176340
Logic pro 10.8.1 is out with a fix.
November 30, 2023 at 3:27 pm #176344
I updated to Logic 10.8.1, then reinstalled Blackhole. Now I’m only seeing this version
Even though both plugins are installed:
I’ve completely rebooted my Mac after the install as well and it hasn’t helped.
November 30, 2023 at 5:51 pm #176350
Same here…Apparently it isn’t fixed.
December 1, 2023 at 9:37 am #176387
Same problem.
December 4, 2023 at 3:08 pm #176510
What we’ve found in our Logic 10.8.1 testing is that sessions saved with Blackhole will reload correctly, but only Blackhole (No MIDI) is available in the insert menus.
We will need to reach out to Apple and find out if this “partial” fix was intentional.
December 13, 2023 at 11:45 am #176727
I was just trouble shooting this problem for a few days, reading this thread and trying out the advice to no avail. I updated to the latest version of Logic the other day and still no luck. THEN I saw this error message more clearly! It said the component “Blackhole (” is not available! Not “Blackhole No Midi” or “Blackhole (No Midi)”. SO! I tried to rename the Blackhole No midi Component that I had moved out of the folder to the desktop to “Blackhole (“, put it back in that folder from where it came and lo and behold!!! IT WORKED!!! Old session now opens with the plugin!!! Not sure if I have an isolated case here, but figured it could definitely help someone out!!
October 14, 2024 at 5:45 pm #185378
So, almost a year later and still no fix?
October 25, 2024 at 6:19 pm #185787
Unfortunately, Apple never fully reverted the changes made in Logic Pro 10.8 and Logic Pro 10.8.1.
This is the stated behavior as of Logic Pro 10.8.1 (from the Logic Pro engineering team): If there is an Audio Unit that is available as effect and midi controlled effect, the midi controlled effect is hidden from the plug-in menu. It still is available for existing projects, though.
So, existing sessions will reload correctly, but only Blackhole (No MIDI) will be available in the insert menus. Apple does not seem willing to change this behavior, so Blackhole will not appear in insert menus.
The only difference between Blackhole (No MIDI) and Blackhole is the lack of MIDI control in Blackhole (No MIDI). When used as a standard insert, Blackhole (No MIDI) will provide the same sound and experience as the Blackhole plug-in did in versions 10.7.9 and prior.
What issue are you running into that you hope to have resolved?
October 30, 2024 at 5:49 am #185893
Can’t you just flip names and have “Blackhole” regular for audio fx inserts and make the MIDI one “Blackhole (MIDI)” or something?
