Home › Forums › Products › Plug-Ins › Blackhole says it ”isn’t available on your system” on OS Sonoma 14.1.1
- This topic has 4 replies, 3 voices, and was last updated 10 months ago by
Eventide Staff.
November 24, 2023 at 3:35 pm #176098
Whenever I open up a project that I originally had used Blackhole on in Logic Pro X version 10.8 using Rosetta (I’m using a 2020 M1 MacBook Pro with 16GB RAM and 2TB of storage) I get an error that says the following: ”The plug-in named ”Blackhole” isn’t available on your system. Choose another plug-in, or quit Logic Pro and install the plug-in on your MacBook Pro in order to use it in the project.”
I tried going into the ”Library” folder on Mac and then deleting the Eventide Folder and the Logic Pro X.plist, shutting down Logic, then restarting it up again but it seems to not be giving me any Solution so far. Also, I tried re-installing Blackhole from the Plug-ins page on the Eventide website on the Blackhole page on the Downloads section where it just gives the option to download the Mac-64-Bit Installer of Blackhole, shutting down Logic Pro X, and restarting it again but it appears to give me the same error as I stated before with Blackhole not being available on my system, and Logic telling me to install it again. Very frustrating as Blackhole is in a lot of my song projects that I use so I basically need it to work.
Is there any way to fix this in order to make Blackhole work in Logic Pro X again? I’ve attached a screenshot of the error I get from Logic as well regarding what I said with opening any projects I had already with Blackhole being used in them.
Any help is greatly appreciated
Thanks, Jason.
November 24, 2023 at 3:39 pm #176099
Sorry for the issues you are having. There are steps in the thread below that should resolve this:
November 24, 2023 at 4:20 pm #176101
Thank you! It works in my projects now 🙂
June 18, 2024 at 12:31 pm #183316
hello there i just got a new mac book pro i am running mac os sonoma and only the Au of black hole is showing up in Ableton and can’t see the vst version is there anything i can do to get it working properly thanks
June 18, 2024 at 1:10 pm #183326
I would first suggest running the plug-in installer again, making sure the VST boxes are checked.
If they are still not showing up after that, go to Settings > Plug-ins in Live and option+click the “Scan” button to perform a deep scan. Note this is not the same as just clicking the scan button, please make sure you option+click and that should resolve the issue.
