Blackhole VST not showing.
Home Forums Products Plug-Ins Blackhole VST not showing.
    • #113382
      Just bought the Blackhole VST and installed it. iLok is running and it’s been activated. Blackhole.dll shows up in my VST folder, with the rest of my apps, but it doesn’t show up in the DAW. Re-Indexed plugins and updated my instruments, too.
      Windows 10 Home 64bit.
      Studio One Pro 2.6.2
      Any ideas? Thanks.
    • #143059
      tlongabaugh
        Hi Silmane-
        Can you try the following?
        1. Open Studio One, go to your VST preferences, and make sure "Scan at Startup" is checked.
        2. Also click "Reset Blacklist" in the VST preferences, and then restart Studio One.
        if that does not work, make absolutely sure that you installed the correct 64-bit or 32-bit version (depending on the version of Studio One you are running) to your VST folder.
        Best,
        Tom
      • #143064
        Hey, Tom.
        That worked. Perfect. Can’t wait to try this out.
        Thanks.
