Bluetooth? What Bluetooth?
Home Forums Products Stompboxes Bluetooth? What Bluetooth?
    • #177755
      NecroBemis
      I’ve updated all the apps and firmware, but my ipad is not “seeing” the H90 via bluetooth. Is there a certain sequence in which I’m supposed to connect? Are there specific instructions for getting the bluetooth functionality up and running?
    • #177759
      Yes, Bluetooth pairing/connection instructions can be found here: https://cdn.eventideaudio.com/manuals/h90/1.7.5/content/system-menu/bluetooth.html#content-system-menu-bluetooth–page-root
      Please carefully follow the instructions as there are specific steps you will need to follow for this to work correctly.
      Let me know what happens.
    • #177855
      NecroBemis
      Got everything connected, but still no go. Finally had to remove the USB version of the app before the bluetooth version would kick in. (Didn’t find that little tidbit in the documentation.)
      So all good now, everything up and running. 🙂
      • #177858
        Glad to hear you got it working.
        I’m not sure what you mean, there is only one version of the H90 Control app, and this works for Bluetooth or USB connections. Running the installer for the latest version of H90 Control should also uninstall the previous version.
