Home › Forums › Products › Stompboxes › Boss FS-5U
November 9, 2013 at 6:42 pm #111196
hi- trying to use a remote pedal for an on/off function. does the FS-5U work for this???
November 10, 2013 at 7:08 pm #125006
Funny, I was just trying that pedal today too. Didn't work for me either….
November 11, 2013 at 1:03 pm #125007
This pedal has been working great together with my Timefactor for the last 2-3 years. Don't forget to assign the Aux 1 / 2 or 3 in the sysetm's menu to the appropriate function. If using only 1 FS5-U it is on Ring.
November 11, 2013 at 1:10 pm #125008
Works great here. If using only 1 FS5-U "Bypass" must be assigned to "Ring" in the System's menu —> Aux menu
November 11, 2013 at 4:29 pm #125009
zwolf:
I've never tried using this particular pedal, but if you're trying this with an H9, be sure to configure the expression pedal / aux switch jack to expect an aux switch. You can do this in H9 Control under pedal settings, and by default, it's configured to expect an expression pedal…
November 11, 2013 at 7:16 pm #135813
thanks for chiming in folks. I just got it to work, but for me it only works with a normal patch cable with the switch setting at T+R. Stereo cable did not work. No problem though, it's working great like this.
November 11, 2013 at 7:49 pm #135814
thank you all for the quick response…
