Boss FS-6/H90 compatibility.
Home Forums Products Stompboxes Boss FS-6/H90 compatibility.
Viewing 4 reply threads
    • #176753
      mvaughan89
        I am looking for a footswitch that I can program to turn on and off the two effects in an H90 separately.
        Is the Boss FS-6 a compatible switch?
      • #176754
        joecozzi
          Hi mvaughan89,
          The Boss FS-6 is not a switch we have tested, but from reading the manual, it is possible to change the polarity of the switches from Normally Closed (NC), which is the Boss standard, to Normally Open (NO), which tends to work for most non-Boss pedals. Also, the switches should be set for momentary operation, not latched.
        • #176755
            Just to confirm, I have a pair of FS-6s I use with everything – including the H90 – set up exactly as Joe described above.  The LEDs are kind of useful to indicate which modes you’ve set the little slide switch options to.
          • #176756
            mvaughan89
              This makes me happy! Thank you!
              I ordered an FS-6 without confirming lol
              Is it possible to set one to tap and one to switch between Performance and Select mode?
            • #176759
              joecozzi
                Yes. All assignable functions can be found here, including Tap Tempo and Mode toggle: https://cdn.eventideaudio.com/manuals/h90/1.7.1/content/appendix/global.html
