Boss FV500H or FV 500L?
Home Forums Products Stompboxes Boss FV500H or FV 500L?
Viewing 7 reply threads
    • #111634
      sonicglue
      Hi! Can anyone tell me if it is better the boss FV500H or the FV500L as expression pedal for Eventide H9? Or are the same? Thanks!
    • #125966
      Mcdookus
      My understanding is that it shouldn't matter. The H and L signify the impedance of the pedal and that only matters if you're using it as a volume pedal
    • #125967
      bucketbot
      I am using the L and it works really well. 😉
    • #125970
      sonicglue
      Thank u!
    • #136687
      sonicglue
      Thank u! I suppose you're using for guitar, aren't you?
    • #137148
      Sorbz62
      What cable do you use to connect the boss pedal?  I have the same expression pedal but it does not work 🙁
      Jim
    • #137149
      sonicglue
      A setero cable
    • #126482
      bucketbot
      I have both pedals and they both work equally well as long as you use a TRS  cable from the pedal EXP jack.
      The can also both be used with a Y Insert TRS to Dual TS from the Input & Output jacks but like this the FV500H tends to be better.
