March 28, 2008 at 4:15 pm #105511
Hi!!! I'm the happy new owner of a secondhand H7600.
The problem is that it won't start up. I get this message after it loads the presets:
A bus error has occured
Program: 00E8B4
Data : 1341753I've written a mail to support, but i'm offcourse eager to try the beast, so i hoped that one of you guys could maby answer me if there's a chance i can solve this with a firmware update?
Thanks in advance, Morten Berthelsen…
March 28, 2008 at 4:47 pm #117257
Hi Morten
(from DK?) try powering on the "beast" and PRESS & HOLD the 8 key when you read H7600 on the display. You'll be prompted to reinitialize (loose all stored info) the unit. Press the YES soft key. this will reset the unit as it should, after an used purchase and probably a shipment.
Congrats!
I
March 28, 2008 at 5:45 pm #117260
Yes, from Dk
You too?
I tried your suggestion, but it didn't work. I get the same message…
March 28, 2008 at 5:51 pm #117261
Yes, from DK
You too? Or how did you guess?
I tried your advice, but unfortunately it didn't work. I still get the same message…
March 28, 2008 at 6:33 pm #128366
Hi Morten. iknow people there, with same name as yours…. ;-9
has your unit been shipped from long distance?
can you try unloading the current presets by powering it on and pressing & holding the PROGRAM key, then YES on prompt.
Is your power stable?
please let me know
I
March 28, 2008 at 7:43 pm #128367
Aaah, ok. Good cal, he he…
Tried unloading the presets as well, didn't work either.
The power is stable as a rock. Just ran it 5 minutes with no problems (other then that it won't start properly offcourse, he he)
It's been shipped from Berlin, and has been on its way and without power for at least 5 days now. Before that i think it haven't been turned on for some time, cause it's from a closed down studio. Don't know if it has been plucked in until it was packaged.
March 28, 2008 at 8:38 pm #128369
Morten
Program: 00E8B4
Data : 1341753is that a specific preset?
can you load a preset/any preset?
I
March 28, 2008 at 8:57 pm #128371
There is a possibility the unit has had some "rough moments" in the shipment. You should try checking/re_seating socketed components.
Power off the unit. Unplug the power cord. Let it there for a couple of hours.
Open the top cover (screws) and look for all square chips that are on a socket. Try gently pushing them down, particularly U106, this is the large square chip near the red and green leds at the front of the motherboard.
Let us know!
I
March 28, 2008 at 10:02 pm #128372
Ok, i'll try that. Hope it doesn't have to go to Eventide for servicing…
March 28, 2008 at 10:21 pm #128373
Ok, just checked all the mounted chips thoroughly, but with no luck. Still the same message.
I don't know if it is of any significance, but i left out a bit of the message i get. The correct message is:
A bus error has occured (E12)
Program 00E8B4
Data 1341753
I left out "(E12)" don't know ifit is of any importance….
March 28, 2008 at 10:33 pm #128374
Check that the battery on the motherboard is both present and good.
March 28, 2008 at 10:36 pm #128375
Year, thought a bit about the battery when i had it open, but didn't know excactly how to check it.
I could maybe pull it out and check with my multimeter… Any other ways?
March 28, 2008 at 10:55 pm #128376
That would be a good way. Should be about 3V.
March 29, 2008 at 1:25 pm #128382
Ok… I have to move my studio today, so i'll have to wait till tomorrow to check the battery…
