Brand New Unit?
Home Forums Products Rackmount Brand New Unit?
Viewing 3 reply threads
    • #106658
      lionelred
      Hi there
      I wrote acouple of weeks ago about my unit. being an 8000 in a FWCase
      I have now been sent a new great, however
      There is a fleck of silver on the screen and was wondering how to remove this without damaged the screen.
      Does it have a factory plastic seal on it or is that the LCD?
      It may be trapped inside the unit if so how easy is it to access the screen?
      Thanks
      Lyle
    • #119534
      On a new unit there is a peel-off protective film.
      Otherwise,  everything depends upon exactly where your fleck is.
    • #119535
      lionelred
      Is there an obvious pull tab plastic like on a mobile?
      There is no plastic tag but the screen is matt?
      I have attached a picture its centre top right
    • #130662
      The plastic is pretty obvious – you would see it if it was there.
      See if you can pick it off with your fingernail or something else that won't damage the plastic. Otherwise contact support@eventide.com
