Bug: H9 Control crashes when using certain preset names
Home › Forums › Products › Stompboxes › Bug: H9 Control crashes when using certain preset names
Viewing 5 reply threads
    • #112072
      Bodde
        Each time I tried to save my H9 Control crashes (Mac version). I couldn't figure out what it was.Tried everything and nothing helped.  But today I discovered that it was because of the name you use to save your preset. I tried to save it under the name "Dotted 1/4". But that doesn't work. All other names work. Apparently the H9 cannot save the "/" sign and therefore crashes.
        Anyone noticed this before? and are there more signs that the H9 cannot save?
      • #126953
        gkellum
          Thanks for letting us know. Each preset is just saved as a file on the file system. So, any characters reserved for special use by the file system like '/' aren't going to work.
        • #126954
          Bodde
            ok, thanks. Any other characters that can not be used?
          • #137587
            gkellum
              Well, I was just looking into it. Apparently on Mac you can't use ":" or "/" and on Windows if the file system is formatted as NFTS which I believe most are nowadays you can't use: / ? < > : * | " .
              So, in the next release of H9 Control, there will be some restrictions in the new preset and preset list dialogs that won't let you enter those characters..
            • #137590
                gkellum:
                I thought that H9 Control would crash with a preset name of more than 16 characters.  (Not possible dialing in the Stompbox itself).  But it must have been a version earlier than 1.6.2, or an illegal character in the preset title.
                One thing that I have noticed in 1.6.2:  The Repeat function loses sync between the H9 and H9 Control.  That is, if I have Repeat latched (in one of the TimeFactor algos), then "page" to my PitchFactor, Repeat is Off when I page back.  Visually, H9 Control is indicating Repeat = Off.  The H9 itself will display REP ON (and audibly verify).
                Clicking again in H9 Control reverses the scenario (still out-of-sync).  This vice-versa behavior continues until another preset is loaded.  Windows 8.1, and all actions within H9 Control itself.  I haven't checked yet for that same kind of quirk using an aux switch or MIDI.
              • #137591
                gkellum
                  brock:
                  Yeah, it's been possible for the performance switch to get out of sync since H9 Control was released. I'll have to take another look at the problem, but we're getting close to a release now and that will have to wait until after the current pending release…
