BUG OR NO?
Home Forums Products Stompboxes BUG OR NO?
    • #166993
      brockstar
      Ok I’m working on the H90 hardware and im in preset mode.
      I got something set for slot A that I like, but now I’m testing things I want in slot B and i find something I like.
      I hit the routing button and then click on quick knob 1 and “swap” the positions and check it and decide nah I’ll go back and hit quick knob 1 to swap back.
      I go back to the preset section I was at and it starts all the way to the beginning of the preset list and I lose my spot where I was when testing presets.
      Works fine on the H90 control app though. If I hit swap on the hardware, it doesn’t lose my spot in the control app.
    • #167013
      brockstar
      Can someone go and try this and see if it happens for them?
    • #167016
      I can reproduce this issue and will forward this to the developers. In the meantime I would suggest using H90 Control if that workflow is better for you. Thanks for reporting this.
      • #167017
        brockstar
        Thank you very much 🙂
