BUG – Ultrachannel 2.0.9 – 12db lowcut Filter phase inverted
Home › Forums › Products › Plug-Ins › BUG – Ultrachannel 2.0.9 – 12db lowcut Filter phase inverted
Viewing 3 reply threads
    • #111803
      violetpow
        High end channelstrip with high end bug.
        While mixing i realized, that only the 12 db lowcut filter in the EQ is phase inverted.
        Also what i mentioned early on 2.0.5 , that the delay sync (synctempo) doesn't work on Ableton Live 9.
      • #126371
        tlongabaugh
          Hi violetpow-
          I've been able to reproduce the phase issue here, and we will definitely look into it. Thanks for bringing it to our attention.
          As for the delay sync issue, could you give us a bit more info as to how it doesn't work for you in Live? Does it not sync to the right beat, or not follow automation, or something else? Additionally, are you on Windows or Mac, and is Live 32 or 64-bit?
          Thanks,
          Tom
        • #126389
          violetpow
            Hi Tom,
            thanks for fixing this filter issue.
            The problem with the delay happens on Live 9.1.3 64Bit OSX 10.9.
            To the delay bug. Usually, if you press the button "systemtempo" it should recognize the song tempo, when you press play in Live 9. But the ultrachannel doesn't recognize the song tempo. If you set the tempo manually in the plugin to the songtempo, the ultrachannel delay is in sync.
            greetings
            Mat
          • #137090
            tlongabaugh
              Hi Mat-
              Is this using the AU or VST version? I've been able to produce the system tempo issue in Live 9.1.3 on OSX 10.8 using the AU, but not VST. Regardless, we will look into the issue. Thanks again.
              Tom
