Building a custom Auxswitch interface!
Home › Forums › Products › Stompboxes › Building a custom Auxswitch interface!
Viewing 0 reply threads
    • #107179
      Hey friends!
      I found a dusty old digitech mc 7 midi controller in my basement. After good 15 minutes of planning banks and patches, I realized that the digitech would be an optimal foot controller choice for my two factor and amp switching pedal board! I opened the chassis and it has a lot of space inside!
      http://farm4.static.flickr.com/3461/3834234926_989fb081e8.jpg
      It would be possible drill 4 holes for aux-switches and some interfacing jacks!
      If someone with knowledge in all this "tip-ring-sleeve-ground" -stuff would help me out here! This is the configuration I would use:
      Timefactor auxswitch out to digitech "custom aux in 1"
      Modfactor auxswitch out to digitech "custom aux in 2"
      In the digithech there is space for 4 switches! I would use 2 for each factor, so here is the tricky part:
      would it be possible to have a third jack in the digitech for a "tap tempo in", that would be a shared switch for both MF and TF, as both of them have one auxswitch left unused?
      Thanks in advance!
