BYP control via MIDI I/F
Home Forums Products Stompboxes BYP control via MIDI I/F
Viewing 0 reply threads
    • #106009
      beagle
       I know that we can change many parameters to receive MIDI control command .
      One of controlable parameter is BYP and by manual,it looks TOGGLE bypass(ON/OFF).
      If so, I think this is not enough.
      I really hope Eventide prepare both BYP-ON BYP-OFF parameter.
      If BYP will toggle bypass, when TF bypassed and receive BYP MIDI CC then TF goes to active.
      On the other hand,when TF is active and receive BYP MIDI CC then TF goes to bypass.
       In conclusion,we can not control bypass ON/OF freely via MIDI CC.
      It is depending on TF bypass condition immediately before receive MIDI CC.
      I'm considering to set up Dry 100% MIDI CC, but this is tricky.
