June 27, 2008 at 11:05 am #105704
me
MemberHi !
I can't assign the global bypass function to any Externals. I mean… of course i can assign it but it doesn't work even when the MONITOR is showing how my latch-switch is going ON and OFF in EXTERNALS menu. I've tried with momentary switches as well. I've also tried with different externals Every other parameter in the eclipse can be controled remotely in my unit: via MIDI CC or the pedals connectors in the rear, but I can't make it work with the GLOBAL BYPASS which I got it set as RELAY BAYPASS. (It works just fine bypassing FXA or FXB but not the global bypass). Can anybody help. please?
t hanks!
June 27, 2008 at 1:15 pm #117606
IDeangelis
MemberHi
which OS version is your unit running on?
Which footswitch are you using? Passive ones are recommended vs. battery powered.
best
I
June 27, 2008 at 4:39 pm #117608
me
Memberhello,
last week i updated to 3.5 and I've tried all kind of switches (active, passive, momentary, latch, shortcircuit-ing the tip to the ground…) I think the footswitch is not a problem, because the ECLIPSE reads pefectly the status ON/OFF of the external switch.
June 27, 2008 at 5:01 pm #128770
IDeangelis
MemberHi
In the current OS version 3.5 the System Bypass is broken. I have 3.5B2 on my unitand the problem is fixed, along with some other cool functions in the MIDI CC area.
It will be released shortly, as stated in another post today.
All the best
I
June 27, 2008 at 7:36 pm #128771
me
MemberI'm very happy to hear that. I will be waiting for the update !!!!!
thanks !
July 5, 2008 at 8:35 am #128786
scottburk
MemberDoes global bypass work in version 3.1?
July 7, 2008 at 12:25 pm #128789
me
MemberI don't know. I've just tried the global bypass in the current 3.5 version.
Javi
July 7, 2008 at 4:13 pm #128791
IDeangelis
MemberYes.
I
July 15, 2008 at 9:05 pm #128817
scottburk
MemberAny word on the 3.5B2 release? I had to switch back to 3.1 because I have to have global bypass that I can switch from my GCP.
July 15, 2008 at 9:40 pm #128819
Should be this week or next at the latest.
July 15, 2008 at 10:01 pm #128821
scottburk
MemberGreat. Thanks, Nick.
July 18, 2008 at 4:22 pm #128826
It has been released and is now available …
July 21, 2008 at 6:42 am #128832
axlbirdeng
MemberThanks for information
