Bypass problem
Home Forums Products Stompboxes Bypass problem
    • #105706
      smilevil
      I'm a new italian (sorry, my english is bad..) user of modfactor.
      This stompbox is very cool, but i have a problem…
      How can bypass mod factor when i press, for example, the n?4 button of my midi pedalboard?
      thanx!
      Lorenzo
    • #117619
      IDeangelis
       ciao Lorenzo
      BYPASS as many other aspects in ModFactor can be controlled via MIDI. I don't know what your pedalboard switch 4 is sending out…but you should check the ModFactor manual to understand how to patch a MIDI CC message to BYPASS. You will need to program your pedalboard switch to send out a specific MIDI CC#, which in turn you have assigned to BYPASS in the Eventide. Then your switch will toggle ModFactor Bypass on and off.
      best
      Italo
