Hi All,
Trying to setup the bypass function via a CC#. I have a FCB1010 Floorboard. Went into the TF and set CC0 to bypass. No luck, went into the learn function and it picked up CC0, by when I click it, still no bypass.
Is there something special I need to do here? The value for the CC is set to 0, but I don't think that should matter for this function.( I tried 1 anyways, still no change). I also tried several different CC#'s with no luck. The TF can pick up the channel as it grabs the correct CC in learn mode.
Anyone know what I am doing wrong here? Does the Bypass mode need to be set a certain way?
