Home › Forums › Products › Vsig and Preset Development › c_graph offsets question
May 5, 2020 at 3:52 pm #115896
rskaudio
ParticipantHey all,
First off, I’m very new to VSIG so apologies if this is an obvious thing.
I’ve been modifying the Satellites preset to be a Mono In & Stereo out rather than Quad out. Along the way I’ve been working on figuring out Wet/Dry blends and Stereo Width’s instead of Pans to reduce the number of knobs on it. One of my initial goals was to add a “delay master” knob that could shift all 4 of the delays evenly (maintaining their relative offsets). I came across the c_graph control in Preset 1127 Comp(4bandFIR)_S which looks like it would do exactly what I was looking for. I set up one in my Satellites one and although it displays correctly it’s not actually changing the delay times (clicking on the sliders does though). I went back to the Comp preset and have been reading the description over and over trying to figure out what I’m missing and then today I actually adjusted the master gai (M_Gain) in the preset with Audio and although it’s showing that it’s increasing the gain on all the bands it doesn’t actually change the audio (mimicing what’s happening in my preset). Is there some sort of On/Off for this process or ?
I’ve attached the VSIG file I’ve been working on for reference, it’s the Dly_Graph object I’m working on.
https://www.dropbox.com/s/hkx38asdr3fjct2/Satellites%20RK%20Test%20V1.2.sig2?dl=0
Conversely, is there a better solution to having independent controls along with an overall master for them?
May 5, 2020 at 9:05 pm #154805
Hey,
c_graph is definitely the right module to use – however, I don't think the offset control is working properly. I've added a bug ticket and we'll fix it for the upcoming release 1.2.4. This is currently in beta, and we're planning to go public beta soon, so you won't have long to wait.
Joe
May 6, 2020 at 2:15 pm #154808
rskaudio
ParticipantThanks for confirming, feel a bit better that I wasn’t stuck on stupid with that.
A request for c_graph2 would be the option to change to knobs & a single slider or all knobs (unless I did miss it).
May 6, 2020 at 3:24 pm #154809rskaudio wrote:
Thanks for confirming, feel a bit better that I wasn't stuck on stupid with that.
Thank you for reporting it. This is fixed, and the fix will be released in 1.2.4.
We can look into changing to knobs instead of vertical sliders as an option. As with all GUI things, layout can get tricky.
