CAA OD50se+ clipping Timefactor in the loop
Home Forums Products Stompboxes CAA OD50se+ clipping Timefactor in the loop
    • #112569
      Hi, I'm getting terrible clipping in the loop with my Eventide time factor, when I check the input level it's off the scale. Love the amp but I really need this delay to work.
      It's the only thing in the loop, input and output on Time factor are set at line, the Front amp level is set on 4 which CAA say should be fine.
      Do you know if There's a way to cure this, is there a way of reducing the input level on the pedal?its a great delay pedal, the amps a keeper so I really need a delay that will work faultlessly in the loop?
      Thanks James
    • #139137
        Sounds like your loop is rather hot. Make sure the TF switches are set to LINE.
