Can H9 do 2 expression pedals?
Home › Forums › Products › Stompboxes › Can H9 do 2 expression pedals?
Viewing 4 reply threads
    • #112676
      I’ve figured out how to use a Y cable to input an expression pedal and an aux switch that can be programmed for any number of things. But can it do 2 expression pedals? That would be killer if I could use a 4E Dual Axis expression pedal on some reverbs to control both the Mix and the Delay Time.
    • #139650
        Sorry – the H9 currently only supports one Expression pedal.
      • #139653
        JCR
          It can be done with MIDI. I am using a Miditemp F-S-M (Footswitch-to-MIDI) controller which is powered by standard 9V (Boss spec) and can send MIDI data for two expression pedals and two footswitches (latching and momentary) at once. The actions for all four inputs can be programmed by SysEx messages. It is mounted under my pedalboard and is used for expression pedals and a general tap switch for controlling both my H9’s. Works great! This way you can use a 3-button aux switch in the H9′ expression input and let MIDI do the rest. Lots of options for controlling one or more H9’s this way…
        • #139655
          JES
            Couldn’t it take a second one via MIDI?
          • #139656
              It could, but only one could be used as an "Expression Pedal." The other would just be a general MIDI controller.
