Home › Forums › Products › Stompboxes › Can H90 hardware do USB interface
- This topic has 7 replies, 5 voices, and was last updated 9 months, 1 week ago by
amc8.
May 19, 2023 at 2:35 pm #171356
I see a lot of people really interested in pairing the H90 with Tonex pedal and/or UAD Dream, Ruby, Woodrow (or others). I’ve done just that with Tonex and it’s the most flexible rig I’ve ever used. With the H90 having a loop and the amps sims likely to be placed there, is the hardware capable of acting as a USB interface? It would be amazing to avoid the extra A/D conversion, latency, and cables of going into an interface vs coming off the H90 directly via USB.
my board
May 19, 2023 at 2:57 pm #171357
…Is the hardware capable of acting as a USB interface?
Nice Board! The answer to the your questions is no. The USB cannot be used in this manner.
I also have a ToneX on my board. I set the H90 to Dual Routing Mode and connect Path 1 to the front of the ToneX in mono. Then, I take the outputs of the Tonex in stereo and connect it to Path 2 of the H90. Fantastic results. Never been concerned with latency.
May 19, 2023 at 3:04 pm #171358
my H90 usb c connection with a brand new mac boock pro do not work…
May 19, 2023 at 3:07 pm #171359
Interesting. Care to elaborate on your choice of dual routing? I thought I had mine setup the most efficient way but maybe I’m mistaken. What advantages does that give over insert? My routing is below
Guitar -> Drive 1 -> Drive 2 -> Input of H90
H90 Loop -> Tonex Pedal
H90 Stereo Output -> Boss RC-10R -> Walrus Canvas Stereo
Morningstar MC6 Pro controlling H90, Tonex, RC-10RWith the above setup I can either use it as an ampless rig with Tonex amps and take XLR’s from the Canvas to FOH, Monitors, or an Interface. I can also take from the TS, sum to mono, and go into a power amp with the Cab Sim Turned off in the Tonex. Conversely, I can make presets in the H90 without the Tonex Insert and run it into the front of a tube amp (also summed to mono), do a wet/dry rig taking from each of the TS, etc. Originally I had to 2 drive pedals in the loop with the Tonex but moved them to the H90 input. One, so if I go into the front of a tube amp without Tonex I dont have the additional latency of running through the Tonex with it bypassed and two, I can put H90 effects between the pedals and the Tonex amps i.e. maybe a Flanger or something I want before the Tonex Amp in some instances.
May 19, 2023 at 3:22 pm #171360
I chose Dual Routing Mode for the simplicity of setting up a PRE/POST rig. I commend you on figuring out PRE/POST with Insert Routing mode. It’s actually my preferred signal flow with a mono amp; however, troubleshooting becomes bit more difficult considering any one cable goes bad and the entire signal chain is broken, highly unlikely in a properly wired board.
May 19, 2023 at 3:29 pm #171361
Haha okay. I thought I was missing out on some Eventide staff secret. Thanks for the info. Loving the H90 by the way. Probably the best piece of gear I’ve bought in a decade.
March 29, 2024 at 7:59 am #180327
I‘d like to add that audio over usb would be amazing!
July 18, 2024 at 9:28 pm #183866
agreed – audio over usb would be HUGE
