Home › Forums › Products › Stompboxes › Can I make the time factor get that sweeping effect when adjusting the delay rate?
August 4, 2012 at 2:48 pm #108999
I'm trying to get an effect that I've used with another delay pedal. I turn the feedback up and adjust the delay rate while playing in a range of about 200ms down to 0ms. On my other pedal this gives me a sweeping effect and at 0ms the delays squish together ontop of eachother creating a high pitch scream on top of a very low hum.
I wanted to use the Time Factor for this because I can adjust the rate with an expression pedal, which I can't do with the other pedal. But when I set it up for this rather than getting a sweep when I change the rate, the old delay just fades and a new delay is created with a faster rate.
Is there a setting I can change to make this happen?
I made a little video demonstrating what I'm talking about here. So check it out and let me know http://www.youtube.com/watch?v=ZJLwW3DRoxE
Thanks a lot
August 6, 2012 at 3:22 pm #123707
The Digital Delay doesn't do runaway oscillations. Either Vintage Delay or Tape Delay will do the trick.
Thanks,
Nikhil
August 6, 2012 at 5:16 pm #123709
Tried the Vintage and tape delay. They did get closer to what I was looking for. But they still seem to have a weird phaser effect in the feedback instead of being that crisp ring I'm looking for. Also the vintage delay seemed to have a lag on it. When I moved the expression pedal to adjust the rate it would sweep after I shifted the pedal and not while I was shifting it.
Thanks for your reply, if this is the case I will probably have to return this pedal 🙁
August 6, 2012 at 8:21 pm #134750
Don't necessarily return your TimeFactor just yet – I don't have one at my desk at the moment, but when I get home tonight I'll take a crack at getting the sounds in your video. I may not be able to get them exactly, but with a bit of knob twiddling I might be able to get you close.
Thanks,
Nikhil
August 6, 2012 at 10:15 pm #134751
Great, Thank you so much for your help
August 7, 2012 at 4:30 pm #134752
I've been sitting down with a TimeFactor for a bit. While the TimeFactor does have many sounds, you are correct in that it won't do the sounds you've posted in the video. There are a lot of other pedals out there that will, though, and a decent number also have expression pedal inputs.
Thanks,
Nikhil
