Home › Forums › Products › Stompboxes › Can I send bluetooth midi sig througu midi out from h9?
February 18, 2016 at 2:19 pm #113271tozersMember
I’m using h9 with bt-4 bluetooth midi pedal. H9 works fine with bt-4 wirelessy, but it seems it’s not working when I try to control another pedal by connecting with midi cable (ex h9-midi out- midicable-midi in- eventide space)
Is it possible send midi sig taken from bluetooth midi pedal from h9?
February 18, 2016 at 3:56 pm #142611
The H9 cannot currently receive MIDI from Bluetooth and send it out over DIN MIDI as a THRU (never occurred to us).
We will consider this for a future release.
February 19, 2016 at 7:53 am #142625tozersMember
Well my bluetooth midi pedal can’t send midi sig directly but send it through ipad.
Btw, if h9 pass trough midi sig taken from ipad, that will be awesome feature and expand its use as a wirless midi receiver!!! Thank you for reply -
May 18, 2016 at 2:58 am #143388ofenderMember
Hi,I have a little question:
How to setting Midi over Bluetooth?
I can’t use the midi app on my ipad to send CCs to control H9…
I can't use the midi app on my ipad to send CCs to control H9…
In H9 Control if you click on the Settings button in the bottom menubar and go to 'Connect MIDI Device to Eventide Device', you can select an iOS MIDI device and send its MIDI data to the H9.
August 24, 2016 at 4:36 am #144184Blit_95Member
It’s possible to sync the H9 via MIDI/ Bluetooth with Ableton? it will be so helpful to me. To sync de Looper or the delays with the secuences that i lunch with ableton. I know that i can do it with cables, but can i do it with Bluetooth? beacause this appears but it’s not in sync…
August 24, 2016 at 12:04 pm #144186gkellumParticipantBlit_95 wrote:
It's possible to sync the H9 via MIDI/ Bluetooth with Ableton? it will be so helpful to me. To sync de Looper or the delays with the secuences that i lunch with ableton. I know that i can do it with cables, but can i do it with Bluetooth? beacause this appears but it's not in sync…
We've set this up before, but there is so much latency over Bluetooth that this doesn't really work. The H9 can't keep track of the MIDI clock…
