Home › Forums › Products › Stompboxes › Can I take tap tempo into H9 and send out as MIDI clock?
April 10, 2019 at 6:51 pm #115271
lordradish
ParticipantHey, folks,
I’ve been doing a few things to get all of my pedals on my board in sync, and I have an external tap tempo I’d like to go into the H9. My pigtronix infinity looper, however, will only take a midi clock for tempo, so I’m wondering, is there a way to send the tempo out over midi on the H9 (based on the tap tempo in), and then send it to MIDI out, and if so, how would I do this?
Thanks.
April 10, 2019 at 8:09 pm #151679lordradish wrote:
I've been doing a few things to get all of my pedals on my board in sync, and I have an external tap tempo I'd like to go into the H9. My pigtronix infinity looper, however, will only take a midi clock for tempo, so I'm wondering, is there a way to send the tempo out over midi on the H9 (based on the tap tempo in), and then send it to MIDI out, and if so, how would I do this?
Yes. You may enable MIDI Output Clock. You can do so on your H9 or in H9 Control.
On H9: Go to the setting menu by press and hold the HOTKNOB and the right footswitch, then go to MIDI -> CLK.OUT -> ON
In H9 Control: See my attachment.
April 10, 2019 at 8:30 pm #151681
lordradish
ParticipantAwesome, thank you.
April 18, 2019 at 4:22 pm #151759
lordradish
ParticipantIs there a way to recieve MIDI over 1/4 inch on the H9, as there is on some other newer pedals? I’m having some sync problems that I’d be able to address, if I were.
April 18, 2019 at 6:29 pm #151761lordradish wrote:
Is there a way to recieve MIDI over 1/4 inch on the H9, as there is on some other newer pedals? I'm having some sync problems that I'd be able to address, if I were.
No. The 1/4 inch ports on H9 are only for audio and expression/auxiliary swtiches. What sync problems do you have?
April 18, 2019 at 7:04 pm #151762
lordradish
ParticipantI’m using multitap tempo pedal to send a tap to Disaster Area qConnect to send tempo to my Meris pedals, and another to my H9, and they’re always off by a few BPM. I have some other possible solutions, but I wanted to check on this, first.
April 18, 2019 at 8:12 pm #151763lordradish wrote:
I'm using multitap tempo pedal to send a tap to Disaster Area qConnect to send tempo to my Meris pedals, and another to my H9, and they're always off by a few BPM. I have some other possible solutions, but I wanted to check on this, first.
Maybe you can tap tempo on your H9 and send its clock to qConnect then to Meris.
April 23, 2019 at 6:16 pm #151782
camn
ParticipantDoesn’t the qConnect also have a standard 5-pin Midi out?
If not- 1/4″ to 5-pin is really just a converter cable. Anyone could make one.
