Home › Forums › Products › Stompboxes › Can Space pedal control RJM Mini Effect Gizmo?
http://www.rjmmusic.com/minieffectgizmo.php
I believe these RJM's need a MIDI controller to switch loops. Will the Space do it?
Yes, Space has the capability of transmitting both MIDI Progam Change and MIDI CC messages. You should be able to use Space as a MIDI controller to the RJM.
