Can the H3000 (or any Eventide plugs) be used standalone?
Home Forums Products Plug-Ins Can the H3000 (or any Eventide plugs) be used standalone?
    • #112765
      Rhetro
      Hello.
      Can any of the Eventide plugs be used as a standalone application? Or imported into Amplitube etc. Or can they only be used in a DAW.
      Thanks
    • #140114
      tlongabaugh
      Hi Rhetro-
      As of now, Eventide plug-ins can only be used in a DAW, as they are only available in VST, AU, and AAX formats.
      Best,
      Tom
    • #140225
      DGillespie
      HI Rhetro,
      What are you trying to do?  If you're trying to chain our effects after Amplitube, you can use Amplitube in a DAW and put the Eventide plug-in before or after.  There are also some lightweight plug-in hosts if you just want to process live audio.
      Dan
