Home › Forums › Products › Stompboxes › Can the H9 do El Capistan Multi-Head?
December 10, 2016 at 7:16 pm #113866runecoreMember
Hello—i used to have a Strymon El Capistan that i loved when i was looking for a pedal –i wanted to capture a “Robin Guthrie” sound that he had in early Cocteau stuff—and i found it in the multi head section of the El Cap — with the right amount of wow and flutter with alittle tape age and crinkle it was basically Cocteau Twins in a box—well i wanted to go to the next level and get something that would save presets that i could pull up in a live situation and the one “favorite” button wasnt going to be anough and as it turns out they didnt put that function into the Timeline (which is beyond me)—so i ended up buying 2 H9’s figuring i could get there with tthat setup–but i havent found a way to get it done Ive tried many combos with the tape echo to no avail)—
So i guess that this a request to Eventide to put out an Algorythm that can pull off that old Roland Re-201 Space Echo sound
OR if anyone knows of anyway to get ti a similar situation using 2 h9’s i would love to know what you think.
December 13, 2016 at 9:40 am #145137badmelonfarmerParticipant
Hi, Timefactor MultiTap will be the closest … off the top of my head maybe try ultratap it may also get that vibe too.
if the modulation is not to your taste then you could pair the secod H9 adding some wow and flutter.
If you can send me the settings you use on El Cap…. I can see if I can be more specific
December 13, 2016 at 7:35 pm #145144runecoreMember
ok sure — the one i used the most (with the time changin) would be:
time – around 2 o’clock
“Multi” “B” mode
Mix – 12 o’clock
Tape Age – 10 o’clck
Repeats 12 o’clock
Wow & Flutter – 2 o’clock
hiddens
Reverb – 2 o’clock
Boost/Cut – 12 o’clock
Low End Contour – 10 o’clock
Tape Bias – 11 o’clock
Tape Crinkle – 11 o’clock
December 13, 2016 at 7:55 pm #145145badmelonfarmerParticipant
Ok, I dug out my old El Cap, leave it with me a few days and I will see what I can do
December 28, 2016 at 5:26 pm #145266sanchezguitarMemberbadmelonfarmer wrote:Ok, I dug out my old El Cap, leave it with me a few days and I will see what I can do
Just curious to see if it work?
December 13, 2016 at 8:04 pm #145146runecoreMember
ok great hey thanks for you help!
December 28, 2016 at 5:58 pm #145267badmelonfarmerParticipant
Still on my list of things to do, sorry … Holiday period and family took over my time.
Will get around to it
December 29, 2016 at 7:35 pm #145281runecoreMember
Sure i totally understand – thanks i appreciate it : )
January 20, 2017 at 10:36 pm #145534javiceresParticipant
You could use 1 unit in tape mode, with delays set to, say, 400 and 600 mSeconds:
-Feedback between 40 and 80 % with Saturation maxed so the repeats get progressively “deconstructed”. Saturation goes from 0 to 10. The difference between 9 and 10 is really big.
If you need yet more saturation, set the input gain of the H9 higher (system mode in the pedal, or pedal settings in the editor). The pedal will compensate in the output stage for the higher input settings keeping unity gain, but the saturation stage of the Tape effect gets hit harder hence further compressing and overdriving the delay sound.
Heck! I sometimes use TapeDelay set to 100% wet with one delay set to zero delay to give texture to my dry sound and the other delay used as a regular delay.-I’d keep Wow and flutter low, so it doesn’t feel artificial (a value from 1 to 4) but still modulated and lo-fi.
-Filter from 2 to 10 (out of 100).
Then I’d pair that with a rhythmic multitap delay. Trying both possible FX orders: Tape-> Multitap, Multitap-> Tape.
The Tape will provide the modulation and texture and the Multitap the, well, multitap thing.
I’d try both Ultratap with only 4 or 6 taps, or Multitap delay.
Both with very little smearing (if any) and Taper and grouping parameters set to 12 o’clock, a neutral setting.
Then there’s the Resonator effect, it can be used as a 4 Tap Delay into reverb. Just set the resonance to zero. Then use the note #1,#2,#3,#4 parameters to set the filtering (band pass) of each tap individually.One important thing is that VintageDelay might take you close to the feeling / texture of a tape delay.
The filtering is very differing to that of the Tape algorithm wich is a hi cut + low boost. In the case of VintageDelay, it cuts also lows, wich I love, and adds a bit of resonance.
If you set the Bits to something around 11bits it gets fuzzy in a lovely way. Filter to taste, I’d suggest starting around 30 (out of 100). The higher the feedback, the fuzzier/more “deconstructed” diluting the trails.
The you have Depth and Speed for modulation, the modulation of the two delay lines is offset, making it richer. I like to set the speed to Max and depth to 1 or 2.Vintage Delay might give you the texture and modulation you are looking for.
Then again you have the second H9 unit, you can use it with another Vintage Delay with offset delay time/subdivision (regarding unit 1) and offset modulation settings.
You can use TapeDelay + VintageDelay in series… EtcOr you can use the VintageDly and a multitap algorithm.
I encourage you to experiment with the A/B delays mix parameter, starting with it at 12 o’clock in both units. This mixer affects both the delay level and panning for each unit.
While we are at it, if you are not using a stereo rig you are loosing an enormous part of the fun with any Eventide box. At minimum, you should connect unit 1 into unit 2 with left and right jacks, even if you run in mono and use unit 2 to mix the final result in mono. Conecting unit 1 to unit2 with in stereo will give the processing extra richness.
For Robin G sounds I’d suggest also MicroPitch delays with A/B mix set to 10/10. That way the feedback is set to crossed feedback wich results in gorgeous sound scrapes with high feedback settings.
Undulator in Feedback mode and with tremolo set to off, also creates very nice delay+MicroPitch shift drones.
ModEchoVerb and SpaceTime are algo great for enormous multiprocesed modulated escapes. Perhaps more in the vein of a more contemporary R. Guthrie sound…
I could keep writing for hours, but I don’t want to overwhelm the thread.
Javier
January 27, 2017 at 9:36 pm #145615runecoreMember
Ok wow —cool thanks for that!! –my guitar is being repaired right now–as soon as i get it back–im going to try these —
THANKS AGAIN
and other ides would be gratefully accepted ; )
January 31, 2017 at 2:51 am #145649javiceresParticipant
Thanks to you my friend, it´s a pleasure when I can help!
