Can the H9 Emulate the EHX Freeze Pedal?
Home Forums Products Stompboxes Can the H9 Emulate the EHX Freeze Pedal?
Viewing 4 reply threads
    • #180296
      silver_mica
        I’ve got the H9 pedal and was wondering which algorithm might be close to the Electro-Harmonix Freeze Sound Retainer Pedal.
        The EHX Freeze pedal has the ability to freeze what is playing – so, for example, if you play a chord you can freeze that chord so that it continues to drone – while you noodle on top of the chord.
      • #180299
          You can get there with most any of the reverb algorithms, and many of (what used to be known as) the H9-Special algos.  Each one brings a special ‘flavor’ to the table: added EQ, modulation, delays, etc.  So you have the options to make them more SuperEgo-like.
          Here’s a start:
          https://www.eventideaudio.com/forums/topic/freeze-pedal-simulations/
        • #180308
          busbassist
            Really hellpful @brock – thanks.
          • #180325
            • #180328
              viktoraigner
                Hope to see a dedicated freeze algorithm on the H90. At some point an employee of Eventide fielded some questions regarding preferred feature set so I‘m still holding out hope…
