Home › Forums › Products › Stompboxes › Can we get STUTTER for the H9?
July 29, 2017 at 11:53 am #114286td2243Member
As a devoted user for nearly 30 years, starting back to my h3000 purchase in 1989, I would really love to see STUTTER for the H9. Especially with all the glitchy music out these days, this could be a really cool and unique algorithm to bring back. Pretty please?
With the UltraTap you can do some stutter type effects:
https://www.eventideaudio.com/products/algorithms/ultratap
Harpeggiator can also be used as a volume gate if you turns off the pitch stuff. We need to make some presets and audio samples showing this off b/c you can make some neat sounds this way.
We have also talked about making a dedicated algorithm for these kinds of effects…
August 30, 2017 at 1:25 pm #147048aaronlittleMember
I am looking for a tremolo that sounds like this (starting at 30 seconds in) :
September 4, 2017 at 11:45 pm #147105spaceJamMember
That sounds like a RAMP tremolo to me. I’m pretty sure there’s a factory preset that nails that sound.
Thank you for the reply, I will check into it.
September 17, 2017 at 6:22 am #147165antonnotaParticipant
You can get a great Stutter effect with the Harpeggiator algo, set the Pitch and Effects param to none and use only the Groove. You will find a pattern that looks like a square wave. And with Attack parameter, you can make it even sharper like VOX Repeater Percussion effect or smoother and get some kind of Ramp up tremolo. Good luck 🙂
