Can you downgrade firmware on TF?
Home Forums Products Stompboxes Can you downgrade firmware on TF?
Viewing 6 reply threads
    • #116178
      PetermanVT
      I am trying to get a leslie sound like in this video/. However, this guy has older firmware. Can I downgrade from 3.000 what ever it is to a lower version>?
    • #156239
      bohan
      You can but I don't recommend that. We didn't add algorithms in TimeFactor's updates, so you don't need to upgrade/downgrade to get a preset. It's either a preset from H9 Control app, or customized by him.
    • #156240
      PetermanVT
      Here is the video: https://youtu.be/mQ6A1e-pKZA?t=450 starts with the leslie sound he has the presets listed. I think he made these using a TF
      Link to my presets here – https://drive.google.com/drive/u/0/folders/0B_VRsKiS_wnoMXltTjRfU1AwRzQ
    • #156241
      PetermanVT
      here is the video. https://youtu.be/mQ6A1e-pKZA?t=447 I think he made these on the TF and here are the files. The leslie wont load on my TF https://drive.google.com/drive/u/0/folders/0B_VRsKiS_wnoMXltTjRfU1AwRzQ
    • #156244
      bohan
      I don't have any problem importing his preset. You'll need to first update your TF to the latest software using the Direct Updater, then you should be able to use H9 Control to edit/control your TF.
      You just need to drag the preset file in the H9 Control window and then load it into your TimeFactor. I have not problem import that preset. And now I export this preset again for you as attached.
    • #156292
      PetermanVT
      hi that leslie file worked great! how come when I try the other sounds? they sound nothing the video? can you help me with those file as well?
    • #156297
      bohan
      Have you done what I suggested? You can update your TimeFactor, and then just use H9 Control to edit those presets. You can just download those presets and drag those files into H9 Control's application window.
