- This topic has 20 replies, 1 voice, and was last updated 1 year, 5 months ago by
rakotite.
June 24, 2016 at 7:57 pm #113530
jeian
MemberFirst of all, Sorry about poor english
I upgraded my Eclipse from 3.51 to 4.01. it was fine and I reset all parameter, too as i’ve seen that in menual
But I decided to downgrade Eclipse again because of some reason. I followed the all steps and then I could get the complete and cycle the power message
So I turned off the Eclipse and tried to reboot
However after that I cannot get any bootscreen at all. Just can hear the click sound when I try to turn on the Eclipse.
Am I in big trouble ? plz give me some idea.
June 24, 2016 at 10:44 pm #143647
Sorry you are having trouble. Things to do:
1) Follow the instructions in the User manual under "Fixing Strange Behavior, Freezes, Etc."
2) If this does not work, or you can't do it, see if you can try the upgrade again. If you used a card, try a different card.
3) If that fails, it probably has to come in.
June 25, 2016 at 4:40 am #143652
jeian
MemberWhen I power on the Eclipse
I can only hear relay click sound
and cannot see any booting screen at all
No keys working so I cannot even try your suggestion at allDo you think that update or downgrade program can damage bootrom?
or I am in hardware problem by accident while updating
thank for quick reply
Because it’s hard to send eclipse to usa and cost a lot, i want to fix the problem in my country
so I just want to get any clue what is the cause
June 25, 2016 at 7:50 pm #143657
Alas, if your unit is totally dead it will have to come for service. It's probably just screwed up software, but that cannot be fixed remotely on an Eclipse.
You don't say where you are – if in EC, you could talk to Sound Service in Dusseldorf.
June 26, 2016 at 3:58 am #143661
jeian
Memberif I need to send my eclipse, at least i have to spend over 400$ (your standard cost 250 + estimate post cost from South Korea) because of i just update.
that’s why I try to find the solution which I can try in my country
Do you think there is any chance that I can fix my eclipse problem in my country
I also think that It might be software Problem.
June 26, 2016 at 5:22 pm #143667
I'm afraid I think it is unlikely you can fix it in South Korea. I'll look and see if our Japanese people can help.
You are probably right that it is a software problem, but the problem is that the software has been destroyed – I am assuming that the unit is totally dead – please tell me if otherwise.
June 27, 2016 at 1:08 am #143672
There is another option – if you can find another Eclipse, it is possible to revive yours with a suitable card and a suitable cable.
June 27, 2016 at 2:37 am #143673
jeian
MemberYes I have got one more perfect working 4.01 Eclipse.
Plz give me the idea how to revive
thank a lot
June 27, 2016 at 3:24 pm #143678
Please send an email to support@eventide.com, referring to this thread.
We will then send you instructions. You will need a CF card below 2G, and a way to write to it from a computer.
You will also need to take of the top cover of the broken one to change a jumper.
You will also need a 9 pin male to male Null Modem cable.
June 27, 2016 at 5:39 pm #143684
jeian
MemberI sent E-mail plz check.
June 28, 2016 at 1:39 pm #143698
jeian
MemberI sent my another E-mail to your mail plz check again.
thanks a lot
June 28, 2016 at 6:59 pm #143704
jeian
MemberAlmost done. My Eclipse Is turned on.
But one last problem is ROM integrity error is on the screen
Thanks a lot
June 29, 2016 at 12:13 pm #143715jeian wrote:Almost done. My Eclipse Is turned on. But one last problem is ROM integrity error is on the screen Thanks a lot
I'll send you something to fix it. You can ignore it for now.
June 29, 2016 at 7:24 pm #143720
jeian
MemberThanks a lot nick
Now it’s working perfectly. -
May 14, 2020 at 12:00 pm #154859
Zeppelin999
ParticipantHi Nick, hope you’re well. I just bought a Eclips and is ina sort of D.O.A. (the guy who sold it to me sayd that the Ecplise was working before shipping).
So, the behaviour is identical to the one explained in this post: power on, then all lights on and a short sound (“beep”), and then no light, no lcd screen etc. Is there something I can do at home considering the italian lockdown? The “strange behaviour” thing on the manual does not work neither.
cheers
Lucio
May 14, 2020 at 12:19 pm #154860
Hi Vito. I'm afraid that it sounds broken. Your best bet would be to return to sender.
It will be a while before there are repair facilities, although you could try contacting our Italian dealer.
In the meantime, you could try putting it into update mode – if you can it would be worth trying an update as described elsewhere on this sit. If you can't it will need to be looked at.
Or, if you have access to another working Eclipse, we could try a prodcedure that helped other people on this post. To do this, contact support@eventide.com mentioning this post and the word "clone". You would require the other Eclipse, a CF card smaller than 2G, an ability to write the card, and a "null modem" cable.
May 14, 2020 at 2:12 pm #154863
Zeppelin999
ParticipantThans. But No luck: power on + 1 = the orange led lights on for hours… Should I try the booloader option? Thanks
September 15, 2023 at 5:54 am #174171
rakotite
ParticipantHi,
I have a Eclipse with no sound and no display.I think it’s the same problem .
Is it possible to give me the procedure for the bootloader,please?
I am in France.
Thanks,
Best regards
September 15, 2023 at 5:55 am #174172
rakotite
ParticipantHi,
I am in France
Thanks,
Best regards,
May 14, 2020 at 12:42 pm #154862
Zeppelin999
Participantnickrose wrote:Hi Vito. I’m afraid that it sounds broken. Your best bet would be to return to sender.
In the meantime, you could try putting it into update mode – if you can it would be worth trying an update as described elsewhere on this sit. If you can’t it will need to be looked at.
Or, if you have access to another working Eclipse, we could try a prodcedure that helped other people on this post. To do this, contact support@eventide.com mentioning this post and the word “clone”. You would require the other Eclipse, a CF card smaller than 2G, an ability to write the card, and a “null modem” cable.
Hi Nick and thanks for the quick response
I’ll try to update to 4.01 with compact flash. Anyway, shuold I try to load the bootloader too? Or not?
Best
NOOOO – you have enough trouble already.
