- This topic has 8 replies, 3 voices, and was last updated 1 year, 9 months ago by
Eventide Staff.
June 7, 2023 at 3:10 pm #171762
Hi
I searched and searched, but no luck what is the problem – I can see you have heard this question before:
My H9000 (i just bought it used, and saw it working in Emote before buy) now it doesnt connect to Emote here at my home
FW is now updated to 2.1.10(132), it is a wired ethernet – “No device found” in Emote 2.0.5(1)
Network is found in my H9000
what is wrong?
June 7, 2023 at 3:16 pm #171763
Sounds to me like a simple network setup problem. Perhaps the previous owner used it with a static IP-address?
Have you enabled “DHCP” in IP-address settings?
https://cdn.eventideaudio.com/manuals/h9000/2.0/content/setup/h9000setup.html#ethernet-setup
June 7, 2023 at 3:27 pm #171765
Hi I searched and searched, but no luck what is the problem – I can see you have heard this question before: My H9000 (i just bought it used, and saw it working in Emote before buy) now it doesnt connect to Emote here at my home FW is now updated to 2.1.10(132), it is a wired ethernet – “No device found” in Emote 2.0.5(1) Network is found in my H9000 what is wrong?
Oh.. just read your post details.. The Emote version to use with the 2.1.10 beta firmware is Emote 2.1.2, available here:
https://www.eventideaudio.com/forums/topic/public-beta-release-h9000-fw-2-1-10-emote-2-1-2/
(Also, in the beta update manual they ask to quit and restart Emote after firmware upgrade and H9000 reboot.)
June 7, 2023 at 3:27 pm #171766
Yes i have, and i tried “rescan networks” still no device found
i just tried to change the ip in H9000 and i cancelled it, it ask for a password i cancelled it
June 7, 2023 at 3:29 pm #171767
Ok i try it im on Windows 11
June 7, 2023 at 3:30 pm #171769
You need to install Bonjour Print Services for the network to work: https://cdn.eventideaudio.com/manuals/h9000/2.0/content/emote/getting_started.html
June 7, 2023 at 3:29 pm #171768
You don’t need to change the IP address, please leave the default settings. DHCP will be on by default.
What are you using to connect the H9000 to your computer? Are you using Windows or Mac?
June 7, 2023 at 3:35 pm #171770
Yes! Bonjour install did it!
thank you!
i overlooked that…sorry
now it works 🙂
June 7, 2023 at 3:45 pm #171771
Good to hear!
