December 9, 2016 at 2:14 pm #113863
I have been have a terrible time of trying to get Eventides 910 plugin into Presonus studio one 3 pro. I cannot seem to find anything that will work on line. Attached you will see what has been downloaded into my computer after I try to install it. Thanks
December 9, 2016 at 3:24 pm #145081
Hi kingsley888,
You should be able to run H910 Harmonizer on your Mac by downloading this installer and running it. https://www.eventideaudio.com/downloader/8900
This should install the VST and Audio Units plug-ins on your Mac, which should show up in the plug-in list of Studio One 3.
Dan
December 9, 2016 at 4:31 pm #145083
Hi-
Please follow these steps if you are on Windows.
1. Confirm that you have the latest version of the plug-in installed.2. Make sure the plug-in is activated in the iLok License Manager.3. Eventide Plug-ins are installed to the following locations, please make sure that your DAW is set to look at the applicable custom folder:- VST32: c:Program Files (x86)Common FilesSteinbergVST2Eventide
- VST64: c:Program FilesCommon FilesSteinbergVST2Eventide
4. If steps 1 to 3 don't solve your issue, close your DAW and run the Plug-in Uninstaller. The uninstaller is located at Start Menu->Control Panel->Programs and Features->Uninstall a Program5. Open your DAW and rescan you plug-ins, and then shut your DAW again.6. Reinstall your plug-in. If you are installing to a custom folder, make absolutely sure you are installing the correct 32 or 64-bit version.7. Reopen your DAW, and if necessary, rescan your plug-ins.Studio One might require you to do the following:1. Open Studio One, go to your VST preferences, and make sure "Scan at Startup" is checked.2. Also click "Reset Blacklist" in the VST preferences, and then restart Studio One. -
December 10, 2016 at 5:22 am #145097
What exactly am I trying to uninstall? All I see is a H910 Harmonizer bundel.
December 12, 2016 at 6:42 pm #145129
You'd uninstall/reinstall the H910 Bundle. But only do that if you've confirmed that Studio One has the necessary file path to the H910, in your VST preferences.
