Can’t explain…?
Home Forums Products Rackmount Can’t explain…?
Viewing 3 reply threads
    • #106370
      ThreeFingersOfLove
      So,
      I modified a preset from the H-8000 FW, saved it in the card, then tried to load it and I get a "patch could not load – can't explain" message. Anyone?
      Regards,
      Yannis
    • #118901
      IDeangelis
      It may simply be too big!
      Did you mod the preset in Vsig?
      How did you store it to the card?
      best
      I
    • #118911
      ThreeFingersOfLove
      Hi Italo,
      thanks for the answer. I didn't modify the preset in VSig, I just dialed new settings and saved it in the card from within the H-8000 FW (choose Card from the Save menu, then give it a new name and location and so on..)
      Regards,
      Yannis
    • #130019
      IDeangelis
      HI Yannis
      is rhe RAM/Card memory still available to store presets?
      Which preset is exactly the one you tweaked/stored/recalled w/problems?
      Did you store it to the card or the internal RAM?
      Are you recalling it manually or via MIDI?
      Try store it in a different memory area, that is if you stored it to a card try storing to internal ram or viceversa.
      It may have been screwed up for some mysterious reason….
      best
      I
