Home › Forums › Products › Stompboxes › Can’t find pedal calibration on TimeFactor
April 2, 2017 at 12:42 am #114098arcadesonfireMember
I just discovered instructions for calibrating an expression pedal at https://www.manualslib.com/manual/755990/Eventide-Timefactor.html?page=32
But that option doesn’t show up under Utility for me. I’ve got software version 3.0.0. Do I need to upgrade? Or is that an old feature that was scrapped?
I’ve been trying for years to get an expression pedal that doesn’t instantly jump from 0 to 60/100, and this feature sounds killer! Thanks
April 2, 2017 at 1:17 am #146041
You need to upgrade.
September 2, 2020 at 3:15 am #155673bluedaniel714Participant
i have the same problem. i updated the pedal and it’s still not there. please help
September 2, 2020 at 7:23 am #155676bluedaniel714Participant
Thanks for your response! i just went to the manual and didn’t see how to look up Firmware. Could you explain how to look it up to me? I can tell you serial number is TF-00748 and software version is 3.5.0(4). I’m looking into T9 control now – i don’t know what that is. I’ve been using my expression pedal for probably over a decade and really like the functionality of that. Problem arouse when pushing the pedal all the way down it doesn’t go to max value. which disallows one from programming the pedal 🙁
September 2, 2020 at 7:58 am #155677bluedaniel714Participant
never mind i figured it out. Previously when i had went to the update page it gave me two choices in versions: the 3.5.0(4) and a 5.whatever. I chose the 3.5.0(4) because the 5. version says it’s for H9 which I don’t use. I just updated with the 5. version and PedCal is there. Thanks for your help. I also think i learned that “firmware version” is synonymous with “software version”?
September 2, 2020 at 5:27 am #155675bluedaniel714 wrote:
i have the same problem. i updated the pedal and it's still not there. please help
What's your TimeFactor's firmware version? Have you tried using H9 Control with your TimeFactor?
September 2, 2020 at 4:50 pm #155680bluedaniel714 wrote:
never mind i figured it out. Previously when i had went to the update page it gave me two choices in versions: the 3.5.0(4) and a 5.whatever. I chose the 3.5.0(4) because the 5. version says it's for H9 which I don't use. I just updated with the 5. version and PedCal is there. Thanks for your help. I also think i learned that "firmware version" is synonymous with "software version"?
Yeah. The 5. is the latest firmware/software version. And with the latest firmware, you'll be able to use H9 Control to remotely control, manage presets and change settings for your TimeFactor.
