Can’t load Blackhole in certain Ableton
Home › Forums › Products › Plug-Ins › Can’t load Blackhole in certain Ableton
Viewing 3 reply threads
    • #113845
      Today I encountered a problem: I can’t load Blackhole 32-bit in my current Ableton project. The cursor shows “busy” for a while, but nothing happens.
      However, I can load it in am empty/rting project. I even tried to copy that Blackhole from empty project to current project, but then Ableton generates “disabled” plugin box with nothing in it.
      I tried to reinstall Blackhole as well as update iLok, nothing changed. Everything else seems to work as usual.
      …now I need that plugin for your remix contest 😛
    • #144986
      tlongabaugh
        Hi-
        Are you on Windows or OSX? We've had reports of this issue, and should have a releasing fixing the problem shortly.
        -Tom
      • #145012
        I kinda fixed it. It seems to be caused by shortage of RAM – yet still I was able to load some other plugins thanBlackhole in same project.
      • #145059
        tlongabaugh
          The newest build of the plug-in should fix this issue.
